Old 06-12-2021, 11:03 AM
greg gfeller greg gfeller is offline
Default Carburetor bowl removal
Does anyone have a simple way to remove the carb bowls for cleaning and float inspection. Every time I weigh my floats its an exercise in futility removing air filters, trying to twist carbs and spilling fuel. I must be making it too difficult. Any sage advice?
Old 06-12-2021, 12:23 PM
seagull seagull is offline
How I do it;
Loosen air cleaner clamp, remove air cleaner, right side has to be worked around hoses. Loosen carburetor boot clamp, pull carb back out of boot. At this point you can lift the carb a bit and release the bail and drop the bowl.
This may be what you are doing and having a tight boot is a challenge. I wiggle side to side, up and down trying not to rotate too much.
It can all be done without removing or disconnecting the control cables, just take care not to kink them while moving the carb around.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Piper J3's Avatar
Piper J3 Piper J3 is offline
You are experiencing the normal process. Patience and calm are your friends...
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
Old 06-13-2021, 08:55 AM
Originally Posted by seagull View Post
How I do it;
Thank you seagull and Piper J3!
