Yes, I do, thank you. I don’t consider myself anywhere competent enough to post my personal opinion on anything structural, which is why my post inferred that if the original poster wanted to hear from the horse’s mouth he may wish to contact Vans directly.
“ Hi Vans,
I've read online that in the past you have approved the use of LP4-3 blind rivets to rivet the leading edge rib rear flange to the main spar web - as you know the technique for bucking solid rivets is a little tricky! I wanted to check that this was an accurate reflection and that using an LP4-3 was strong enough?”
“ Yes, it’s been done many times – you will need some LP4—4 as well in some locations
Vans”
