VAF on Twitter:
@VansAirForceNet
Old 06-27-2022, 08:54 AM
Legdoc Legdoc is offline
Default Mittler ultimate box and pan brake
Good day from South Texas, I am trying to find any experienced user of the Mittler B&P brake but not having much results. Any comments on this item would be appreciated.
Thank you!
Old 06-29-2022, 09:09 PM
This B&P brake must not be a very common item as I can't find anything on this unit here or on other sites.
Old 06-29-2022, 09:49 PM
dpansier's Avatar
dpansier dpansier is offline
Two videos on the Mittler Ultimate Box and Pan Brake
https://www.youtube.com/watch?v=lIbeIBLrI1c&t=8s
https://www.youtube.com/watch?v=bfMM2F5s-h0&t=6s
Don Pansier
Green Bay, WI (GRB)
RV-7
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 06-30-2022, 07:40 AM
HFS HFS is offline
Default Finger Nose Radius
One thing for consideration is that the Mittler (and most other brakes, for that matter), have a very small radius at the "nose" of each bending finger - making a concern for fatigue when bending aircraft aluminum.
You can make a "mask" with a radius (of some accuracy, or not) to slip over the fingers to help with this situation. Unless you make the mask in sections to match finger width, you still have the problem using the brake as intended, with leaves removed as necessary.
YMMV - just a thought.
HFS
Old 06-30-2022, 02:32 PM
I appreciate the help. The Mittler B&P brake must not be very popular as I am having difficulty getting comments from users of the unit. I have seen the videos. They have fingers with various radii for specialty work like aviation. But of course more $$$.
Thanks again!
Old 06-30-2022, 08:21 PM
gyoung's Avatar
gyoung gyoung is offline
The lack of response may be because there's not much need for a high end brake on an RV, even the old "mine your own ore" kits. I like Mittler and talk with them at every show but so far I'm just lusting for their stuff. I've made do with a 30" 3-in-1 roll/brake/shear and a 4' straight brake.
Greg
1950 Navion - flying
RV-6 - first flight 5/6/2021
1940 Rearwin Cloudster project in progress
4 L-2 projects on deck
Old 07-01-2022, 10:26 PM
I am soon to start an experimental build and would think a 48" brake would come in handy. The main purpose is general shop use and trim fabrication on several standing seam roof jobs coming up.
Old 07-02-2022, 12:33 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Looks like a nice brake. I had a Tennsmith 48 finger brake, but sold it because work had a 48Ē National that I liked better. Radiusing the bend can be accomplished by setting the fingers back. Iíd just use a little strip of scrap to find the right setting. Or, like others said, you can bend a piece if mild steel or stainless to add radius to the fingers. Just make sure to set the fingers back accordingly so you donít pinch the target material. That method generally makes a more even radius, if that is important. Having all those removable apron and bed fingers could be handy on rare occasions. I have to tell you though, hitting your dimensions with more than a couple of bends will likely happen only after youíve made a lot of practice scrap! I made a lot of side consoles out of (free) 5052 before I got the recipe down for committing to 2024. And poster board before the 5052!
You really donít need a finger brake for RV kits unless you are making custom parts, like my side consoles. I use the crappy press brake on the crappy 3:1 HF machine I picked up on CL occasionally to make small stuff. Everything on that machine is garbage though. Iíd love to score a nice old Diacro 16-24 manual brake. We had one in our prototyping shop back in the day that had a ton of tooling, like joggle dies, etc. It was awesome. You do give up length though. Have to go big/heavy to get much length in a press brake. In general, hitting your marks is a lot easier on a (good) press brake. Hard to go wrong with anything Diacro. Keep an eye on your local CL and such.
Beyond a brake, I use my Diacro notcher a lot. Very handy. Makes such clean trim cuts. Followed by my old lathe, Tennsmith kick shear, mill, brake, and roller. No punch at this time other than a Whitney 5 and XX.
Have fun!
Mike W
Venice, FL
N164WM RV-6A Slider/O-360/FP Sold 4/2022
N184WM (RV-8) Ready for inspection. Titan IOX-370/ CS/G3X
N184P reserved (RV-8QB) Empennage kit and QB wings in the shop
