Old 10-01-2020, 09:08 AM
Ottoman Ottoman is offline
Default Airflow Performance V AvStar System
I am building an 7A with IO-360M1B CS and it has come to my attention that the Airflow system will have a clearance problem with the stock cowling. Can anyone elaborate on this?
John
Old 10-01-2020, 10:20 AM
Dan92 Dan92 is offline
My 7A has an IO-360, Hartzell CS and Airflow fuel injection and I had no problems with the factory cowl. When you order the kit I think you have to specify what setup you are planning to use.
Dan
Old 10-01-2020, 10:30 AM
DanH's Avatar
DanH DanH is offline
The Avstar and AFP FM150 are same length with the same flanges.
An FM200 might require a cowl mod.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-01-2020, 02:24 PM
Thanks guy's for the quick reply.
I will call Lycoming tomorrow about a change.
Lycoming emailed me this morning about a clearance issue with using the Airflow Performance system, maybe their using the FM200.
John
Old 10-01-2020, 02:49 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default FM200
My cowl needed a mod to fit the FM200. I would have gone with the FM150 had it been available.
Mickey Coggins
Fresh Ukraine update from RV-6 owner Alex 6 May 2022!
http://www.rv8.ch/help-people-in-ukraine/
"Hello, world!"
Old 10-01-2020, 03:57 PM
DanH's Avatar
John
Now that you mention it, I do recall something about a spacer to clear a rotating arm?
EDIT...Here 'ya go: https://vansairforce.net/community/s...d.php?t=159558
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-02-2020, 11:43 AM
Default AFP
Van's called me back late yesterday and basically confirmed what was said on this thread, FM-150 will work with no mods to the cowling, FM-200 will not.
But, the air intake will need a modification!? The FWF kit is set up for AvStar system. Is there an after market kit for the air intake? Van's basically said it will be like putting a square peg in a round hole. Mod? Any feed back on that?
Another thing, after reading the thread from DanH, which refers to the 390 engine, will I need the FM-150 throttle/mixture cable bracket kit? Or will this be done at Lycoming? I guess I can make another call to them.
John
