  #21
Old 11-09-2018, 11:23 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Originally Posted by MConner View Post
And a a 50 year old airframe with retracts and an FAA strait jacket on changes to avionics and airframes? Not even apples and oranges.
Being the manufacturer and maintenance shop, able to do modifications and use your own fabricated parts or "experimental" parts (engine, prop, avionics, EFIS), with less FAA restrictions, is priceless (and less expensive to own because of that). Resale of RV's had proved to be excellent.
For 2 seats side-by -side or tandem there are not many GA aircraft to compare to the RV-7/14 or RV-4/8, so that helps decision to built. Most builders love working with their hands, process and learning.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2021 Dues Paid
Old 11-10-2018, 11:51 AM
jliltd's Avatar
jliltd jliltd is offline
I own a 260B Comanche and it is fantastic, stable, speedy, safe and has a huge CG range. No cowl flaps or cooling problems. And maintenance isn't too bad if kept up with.
Jim
Jim Ivey
RV-8
Old 11-10-2018, 12:14 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Because we're passionate......
Originally Posted by Kyle Boatright View Post
A lot of very rational people would choose the Comanche or an equivalent Bo over the RV-10, given the $100k cost difference. We buy/build RV's (and own Comanches) because we're passionate, not because any of it makes sense or can be reasonably justified.
Kyle,
You hit the nail right on the head with the above statement.
"We buy/build RV's (and own Comanches) because we're passionate, not because any of it makes sense or can be reasonably justified."
Ivan Kristensen
RV-10 (C-GMDV) 1450hrs.
Dual GRT 8.4" HXr EFIS, VP-200, TT A/P, Avidyne IFD440, uAvionixX ADS-B out, Sky Radar WX and Traffic, Dual EI's (one Lightspeed & one SDS CPI)
RV-14A under construction.
An ADVANCED PANEL from AFS. Dual AF5600 10.4" EFIS'
Avidyne IFD540 FMS Navigator, uAvionix AV-30 B/U EFIS
Lycoming IO-390 EXP
SDS EFI/EI FADEC system
Check out my FB page.
https://www.facebook.com/groups/976335912852865
Old 12-30-2018, 04:29 PM
grubbat's Avatar
grubbat grubbat is offline
Default Indicated vs True
Descending out of 17,000ft at VNE (not recommended), the RV-10 would need to keep indicated airspeed around 148kts or less due to the weaker structure. It is true air speed limited to 200kts.
On the other hand, the stronger yet older (50yr) Comanche could descend at 201kts INDICATED which trues out to around 270kts.
Once the -10 gets down to around 8500ft, it'll will be back in the hunt..... unless the Comanche has already landed, refueled, and robbed the courtesy car. (I hate it when that happens!)
Happy New Year!
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 Built and Flying
1965 Maule M4 Bushwacker projectÖ till RV-15 shows up
Old 09-16-2020, 04:13 PM
togaflyer togaflyer is offline
Those are really great planes but the thing that really separates the certified vs experimental world is the yearly inspection. My condition this year was a whopping 51 dollars, cost of a KN filter. 30 plus years of owning a certified plane, never had an annual that cheep.
Old 09-16-2020, 04:43 PM
rocketman1988 rocketman1988 is online now
Happy New Year!
Weaker structure? Hardly. It is more about flutter margins...
Bob
Aerospace Engineer '88
RV-10
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
Old 09-16-2020, 06:36 PM
Brdog42's Avatar
Brdog42 Brdog42 is offline
Default 400 engine
Twin turbo 400 from the factory at KCHD. Piper only made a handful of the twin turbos, BTW. I do not what to know itís GPH FF.
Click image for larger version
ID:	2544  Click image for larger version
Tim
RV-6A restoration in progress
KCHD AZ
Old 09-16-2020, 08:28 PM
A normally aspirated io-720 has a 34 gph FF at TO power, about 23.5 gph at 75%. If it is turbo normalized at 400 hp, 34 GPH continuous wouldn't be out of line...
Bob
RV-10
N464RL
Old 09-16-2020, 11:06 PM
grubbat's Avatar
Default Ok
I stand corrected. Letís modify that to be TAS limited. Comanche still gets the courtesy car. 😜
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
Old 09-17-2020, 01:25 AM
I donít think so. Since both airplanes cruise nearly the same speed on the same power, their drag must be comparable too. To descend at faster than 200 knots true, the Commanche will need a steeper angle of descent. Which means it canít start the descent until later. So while the -10 is coming down at 200 ktas the Commanche is still cruising at 160, then, finally making a very steep and fast descent. Figure in a higher climb rate (-10 has a higher power to weight ratio) and slightly faster cruise, and I think the -10 driver will get the car. Would make for an interesting fly-off, tie down to tie down.
