Keep VAF
Going
01-17-2018, 05:14 PM
Fuel pump failure mode
Our RV8 has IO360M1A and a Tempest Fuel Pump #L15473. When cleaning up the aircraft yesterday after a long cross country I found a trail of gasoline dye behind the fuel pump drain tube. As a check, I pressurized the fuel system with the boost pump on the ground and no leakage was seen. Also, when pressurizing the system with the engine driven pump by cranking the engine, no discharge from the fuel pump drain was noted. The pump has accumulated 1400 flight hours since new.
Does anyone know how these pumps fail? Does the diaphragm slowly crack, or can the final failure be catastrophic? (I had planned to attend the 75th anniversary of my Navy Attack squadron in California this weekend but feel it would be risky to attempt the 9 hours of flight time over barren countryside.)
Any knowledge that you all might be able to provide will be appreciated.
Craig Taylor
RV8 flying
2022 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: Gulfstream, IA Jet, Jetstar, Falcon 10, 20, 50, HS125
01-17-2018, 05:19 PM
Your pump is toast. Replace before next flight. At 1400 hrs you got way more than a life out of it.
Bob burns
Rv4 n82rb
01-18-2018, 06:36 PM
Tim Lewis
CFI, A&P
RV-10 N31TD - 1650 hrs
RV-6A N47TD - 1100 hrs (sold)
01-18-2018, 07:46 PM
I'm no expert.....
....but I think that's cheating!!!! Great tip! I worked at the local car garage when I was in high school. Remember fighting the pushrod on mechanical pumps. This will take all the 'fun' out of it.
Chris Halfman
La Vista, NE
-7A, 360+ hours on the Hobbs, ECi O-360 185 hp, GA200L Whirlwind prop
Anything I post on here may not be the best way, the right way, the only way, or even an accepted way to do something, but it's how I did it. Use the information accordingly.
01-19-2018, 12:29 AM
Put heavy grease on push rod ,can be done using finger , grease will help keep push rod in up position, helps to wipe as much oil off as possible, can be done without removing mag
Jerry Scott
Rocket II
01-19-2018, 01:09 AM
Spot on Jerry. and also a little grease on the gasket to help hold it in place on the pump helps too
Larry
01-19-2018, 08:08 AM
Thanks!
Thanks all, for the great explanations, and the Tempest video. Good stuff. Now on to the replacement.....
Craig Taylor
RV8 flying
01-19-2018, 08:32 AM
Another Trick...
Another trick is to use some thin safety wire to wrap around the backside of the plunger while in the UP position. Once you get the fuel pump in place and the screws started, pull the safety wire out, then tighten down the screws. Works great!
01-19-2018, 11:45 AM
What Mike said!
+1
Wire lacing cord or a cylinder base O-ring works great here , too. Just snip and pull out.
Pete
Amateur Plane - RV-9A N789PH - 2500+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
01-19-2018, 03:25 PM
The secret super sticky grease....(drum roll please): Bosch point grease, 5700-002-005.
Dan Horton
RV-8 SS
Barrett IO-390
Thread Tools |
Display Modes |
