Old 07-29-2018, 09:53 AM
kentlik's Avatar
kentlik kentlik is offline
After much deliberation, I have decided that I am in good shape overall.
I just needed to settle down and realize that this portion of the build is a bit more involved and needs extra attention to the small details. I can tweak this one step at a time.
As my buddy always says: "One crisis at a time Kent"
Going to get at the first wing I think and revisit the windscreen just a bit down the road.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 07-30-2018, 11:04 AM
kentlik's Avatar
Changed my mind again...
Going to get the windscreen at least cut to size and set up on the fuse.
More of the mass amounts of filler removed and top skin all clean
Just about ready to get going tonight have a location to scout in an hour so off I go.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-07-2018, 11:28 AM
kentlik's Avatar
Getting the new roll bar set
Almost home on this darn thing. I cut another new set of anchor blocks to get them spot on. They are cheap and I have an adjustable jig set up so it is pretty fast.
My slider canopy is a bit low even with the spacers compared to the windscreen so a little fudging will take place I guess...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-11-2018, 12:00 PM
kentlik's Avatar
I am calling the roll bar/canopy interface done.
Finally...
I didn't get a shot from the other direction but they are parallel if not a bit more
clearance between.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-13-2018, 05:13 PM
kentlik's Avatar
Started the gear because I felt like it was a good time
Need to clean up the brakes and install them on the new gear legs etc etc
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-24-2018, 08:59 AM
kentlik's Avatar
Default Grips
Got my grips in process
They are foregrips from my Steyr AUG clone project from many years back. I have like 125 of them left over so I thought I would put a few to good use.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-24-2018, 01:51 PM
kentlik's Avatar
Default mount
Got the mount on:
Went in nice and the center two bolt locations came in flush with the firewall so no need for spacers there!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-24-2018, 09:39 PM
jcarne's Avatar
jcarne jcarne is offline
Lookin good man!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 08-25-2018, 11:24 AM
kentlik's Avatar
Originally Posted by jcarne View Post
Lookin good man!
Thank you Jereme! Moving forward as budget permits.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-25-2018, 03:33 PM
jcarne's Avatar
I hear ya man. My wallet just took quite the hit... I ordered the engine and prop on Friday.
Jereme Carne
PPL
