Old 05-24-2018, 08:32 PM
cajunwings cajunwings is offline
Default Edges
Sometimes I’m a fan of overkill. Sanding the canopy edges was one of those times. I went up to 400 grit while the work was going on, but after finished up with 600-800-1200. Was not necessary and it took a few extra minutes. FWIW my old canopy was pop riveted on per plans. Large sections were broken out in the noseover, but surprisingly there wasn’t much cracking at the perimeter rivet holes and the edges were left really rough(around 100 grit)
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 05-24-2018, 08:41 PM
kentlik's Avatar
kentlik kentlik is offline
Don, I can see going with a wet sand of 400 for final. I know I will.
Why didn't you just flame polish it! Sheesh..haha
I have another cut to get the final on the rear and figuring the side cuts now...
Hows cockpit treating you? Work-wise that is.
Thanks for looking Don!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 05-24-2018, 09:38 PM
Blain's Avatar
Blain Blain is offline
Originally Posted by kentlik View Post
Sika. It seems to be a better solution all around Blain.
You won?t regret it.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
Just SuperStol XL in progress
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2022 (my reminder)
Old 05-26-2018, 12:09 PM
kentlik's Avatar
Default Separating the canopy
So far so good
marking jig
Marked
sanded edge
I just need some warmer temps. Cut the forward tool mark portion off yesterday and it was only 65F...seemed fine. This cut I want more heat.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 05-27-2018, 03:57 PM
kentlik's Avatar
Default Magnum Cut
Here we go! Magnum cut forthcoming
The temperature just about there or is it me vacillating
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 05-27-2018, 08:56 PM
kentlik's Avatar
Default seperated
Offset, belt sand this out
and again
Used my Dremel with a whip attachment and a reinforced fiber disc from Dremel at 1.5" dia. Don B. tipped me off to the Dremel fibrous wheel, recommend highly! Worked well and was not terrible to do.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 05-28-2018, 12:18 PM
Default The Cut
We can all breathe a sigh of relief now. I was about to post ?JUST CUT IT ALREADY?. Congrats, it is a big step and expensive if it goes badly. Your planning, layout and execution continue to look good.
Don Broussard
57 Pacer
Old 05-28-2018, 05:29 PM
kentlik's Avatar
Thank you, Don! Anticipation is half the fun. I feel like I made a big leap with this done.
Want to get this on and move to the wings...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 05-28-2018, 06:59 PM
jcarne's Avatar
jcarne jcarne is offline
Congrats on the big cut Kent!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 05-29-2018, 10:04 AM
kentlik's Avatar
Thanks Jeremy! It wasn't all that bad, but I was on a bit of caffeine.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
