Keep VAF
Going
12-16-2019, 11:52 PM
Waiting for the warm weather
Bad timing: I'm ready to start working with canopy plexiglass but it's in the freezing middle of winter. Nope! Gotta look for some other stuff to do in the mean time. Looks like there is plenty of canopy related work, but the plans have you doing them after the plexiglass is in place. Any reason that some or all of these can't be done before the plexiglass work? Canopy reinforcement brace kit, side skirts, canopy lift struts, aft canopy latch lugs (the parts that engage with the latch "fingers"), interior canopy handle. Do I really need the plexi fit to do these?
If I really have to wait, I guess I can set the canopy frame aside and work on the engine mount or something. Or start fiberglassing the empennage. Or start installing avionics. Or the wiring harnesses. Or the stick grips. Or pull the trigger on a panel. Come to think of it there's plenty of stuff to do at this stage!
12-17-2019, 05:15 AM
We don't usually see Livermore, CA and "cold weather" in the same post.  Why not knock together a small workroom out of 2x4s and Visqueen and put a small heater in it?
(2020 dues paid)
12-17-2019, 06:20 AM
I put an electric space heater inside the cockpit of the airplane for part of my canopy work...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
12-17-2019, 08:54 AM
Ryan,
I moved on to working on some engine mount / firewall stuff. There is also the brake assemblies. Well there is always plenty to do it seems...
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
Sensenich Composite 3 Blade Propeller
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
12-17-2019, 09:34 AM
Same Boat
I am in the same boat. Ready to start canopy. But I think I will wire up tail cone and work my way forward. I am not sure if I can do firewall forward without gear on. Plane is too tall for garage with gear and I am height challenged.
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 70%
12-17-2019, 05:57 PM
I did my 7 tipper with the fuse sitting on short supports while doing the canopy, FWF stuff as well as the panel and most wiring etc. (Same issue with the low garage height). I then had to remove the canopy to install the gear while doing the brakes, fairings, cowl, wheel pants etc. I found most tasks were a lot easier with the fuse at a lower height off the gear. Still remember being at the 90 percent done and 90 percent left to go stage!
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
RV4 - Built 2021 Time flown and Sold
RV8 - Building 2022
12-17-2019, 06:03 PM
Yep, after this you will have to stand on a 5 gallon bucket or ladder to do just about anything. Luckily I was almost done with my wiring before I put her on gear.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
12-17-2019, 06:26 PM
Canopy
I did mine in chilly temps in May. Just heat the area before cutting. Actually, I never got above 70. Pretty cold at 7,500'. It can be done. Now I'm working a one piece fiberglass skirt. I would recommend getting the frame as close as possible plus 1/2-3/4" before touching the canopy.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Thread Tools |
Display Modes |
