Old 11-10-2015, 07:56 PM
DHRYCAUK's Avatar
DHRYCAUK DHRYCAUK is offline
Default Powder coat crack?
After changing my oil I was inspecting the FWF with the cowl off and I noticed a crack on my lower engine mount. Not sure if it's just a powder coat crack or the mount itself. I'll probably need to buff off the powder coat to expose the metal, if it's the metal I imagine the repair could be grinding out the crack and fill with weld.
Anybody else have any thoughts?
Central Alberta, Canada
RV-8 Bald Eagle (Purchased April 2014)
Old 11-10-2015, 08:16 PM
6 Gun 6 Gun is offline
Unhappy paint
Maybe just powder coating coming of its put on without a primer check it out and see.
Bob
Old 11-10-2015, 09:04 PM
If it's a real crack, AC 43.13b has repair processes.
You might be able to chip off the powder coat at the crack and expose the metal that way, if it's a powder coat issue.
Dave
Old 11-10-2015, 09:10 PM
sblack sblack is offline
Is that the cup that holds the rubber mount on a dynafocal? Hard to imagine a structural crack there. Mounts crack at the welds typically. This is more likely rust under the powder coat.
Scott Black
VAF dues 2021
Instagram @sblack2154
Old 11-10-2015, 09:12 PM
BillL BillL is offline
It sure seems like an odd place and angle for a stress related crack.
I would chip it off then look for a surface defect.
Bill
RV-7
Old 11-10-2015, 10:02 PM
DHRYCAUK's Avatar
My first thought was a powder coat deficiency, I'll try and flake it off when I get back from vacation in a couple weeks to expose the metal. Hopefully that's all it is.
Old 11-10-2015, 10:40 PM
flyboy1963's Avatar
Default not uncommon
I found some old threads; seems for a time the freshly welded steel went straight to the powdercoaters, and they did NO prep, just shot & baked.
I have a bit of flaking on my engine mount also, probably a circa 2003 or so.
I chipped and shaved down with a wire wheel, did a close visual inspection, primed and touched up as needed.
Not a permanent fix, but your mount isn't exactly 'out in the weather' so future corrosion seems unlikely.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
