Old 11-11-2014, 11:10 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default What would you do with this?
My throttle produces severely offset CHTs and EGTs at about a 75% position. If I dump in full throttle or pull back to 65% or less all the numbers even out nicely though. I've verified I can get a good EGT rise at altitude by leaning. But this spot around 75% has some wicked offsets. Aerosprort was of little help.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 11-12-2014, 12:21 AM
Jordan1976 Jordan1976 is offline
I'd lean the engine out. 11.7 GPH on an O320 is a ton of fuel at 72% power on an O320. It's enough to support almost 170 HP, and you're producing about 115.
Does it clean up when you drop to 10-ish GPH, which is much more in line with a ROP mixture at that power?
What do your fuel flows look like at WOT and 65% power?
--Ian
Dynon Avionics
Old 11-12-2014, 12:39 AM
Dbro172's Avatar
I will have to lean it out and check to respond to your question but I think it has more to do with the butterfly valve setting. I can check fuel flow at wot and 65% power but that will pry mean climbing to 12500 da or so?
I think I'm realizing some significant ram air horsepower or some significant horsepower increase from the ASA vacuum valve because whereas I only get 2150 rpm static at 1500 msl, I can still wind it up to 2750 at 10,000 DA.
Derek Hoeschen
EAA Tech Counselor
Old 11-12-2014, 05:04 AM
A2022 A2022 is offline
Default sump riser insert
do you have a sump riser insert? lycoming SB-258.
Old 11-12-2014, 07:05 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Extremely old SB and it looks like he has a Superior 320. Lean for the altitude and report back, that's a lot of fuel burn.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-12-2014, 07:28 AM
Rupester Rupester is offline
Default Agree with the leaning recommendation
I have likely the same engine in a 9A - Superior IO-320 - furnished by Aerosport Power. At that altitude and at 72% power I'd be leaned w-a-y back and burning 6.5gph or less. Even at <4000 ft running 75% and 100 ROP my fuel burn is ~ 9 to 9.3gph. That 11.7 - as others have observed - is WAY high.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-12-2014, 04:49 PM
BillL BillL is offline
I think if you look at the charts 75% (or less) would be reached with WOT - and leaned to Rupsters range of fuel flow. esp at 9500 ft. This way you avoid that throttle position.
Neither is affecting your RPM. You have a fixed pitch, so with the incoming airspeed the balance RPM match of prop demand and engine power increases. Like full power and going into a dive, RPM will increase.
I added the colored responses above.
Bill
RV-7
