Old 11-21-2021, 10:19 PM
danny danny is offline
Default Slipping a 9
So I was high on final, full flaps. I decided to slip and went full right rudder and whatever aileron to stay lined up on the centerline. My problem is it didn't make an appreciable difference in my descent rate or at least not what I expected. So could it be that with a nose up attitude and full flaps I'm taking wind from my tail making it less effective in a slip?
I haven't tried it with less flaps. Anybody care to share their experiences?
danny
Old 11-21-2021, 10:34 PM
Taltruda Taltruda is offline
danny
Slipping a -9 with full flaps works just fine. I feel that less than full flaps will not produce as much drag as you are getting at full flaps and a slip. Where was the wind coming from? Best effectiveness comes by putting the wind down into the wind and full rudder. You can also try slipping at lower than normal airspeed, it really works well, just don’t lose directional control.
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 11-21-2021, 10:36 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
I've also found that slips in my RV-9A don't help all that much.
One topic I've never read about is what speed gives the steepest descent angle in a slip. Since the -9A has a benign stall, with practice, you could slip at a relatively low speed if that turns out to give the steepest descent angle. Don't know.
Constant speed prop helps a lot in deceleration...
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 11-21-2021, 11:01 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Full flaps, my -9 slips great. Comes down like a rock so long as I use full rudder as well. Partial rudder seems to reduce sink rate significantly.
Do note, however, that your airspeed may not read real accurately in a slip so practice at altitude until you get a feel for it.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2022
Old 11-21-2021, 11:22 PM
JDeanda JDeanda is offline
Default Slip and Slide
Seems like some airplanes, especially low wing types don’t come down much steeper in a slip if you let the speed get high. You may need to make a conscious effort to watch the speed and be ready to raise the nose higher than you’d think necessary. As others have said, practice at least two or three misteaks high. Try flying it all the way to the stall when it’s all cross controlled and see what happens. Most (MOST!) airplanes (Citabrias, Decathlons, all the 1xx series Cessna singles, Cherokees in all their variants, high wing Pipers, Taylorcraft, Champs, etc. stall pretty benign in a slip.) Skids are much different! Notably, our RV-6 will buffet mightily and often break over the top if it’s flown to a standstill in a slip. The -9 is reputed to be very docile so my hipshot is that you’ll just run out of rudder or aileron, then elevator and it will maybe buffet and descend very steeply without departing controlled flight. Please note that I’m not suggesting you do this in the pattern but you need to know what happens in the worst case, and on your way to the worst case before you fly slips in the pattern. As always, YMMV.
Old 11-21-2021, 11:46 PM
MacCool's Avatar
MacCool MacCool is offline
No problem with slips here although I can see how a slip would be more pronounced with a more conventional wing. Forward slips are more effective with flaps in my experience, but either way that big rudder makes it a pretty effective maneuver for me.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 11-22-2021, 08:37 AM
luddite42 luddite42 is offline
Wind/slip direction has no effect on the slip descent rate or angle, it just affects alignment. I see the idea passed around on occasion that slipping into the wind will make you come down faster or steeper which it won't.
Old 11-22-2021, 08:40 AM
sirlegin's Avatar
sirlegin sirlegin is offline
Ditto with my 9A
Nigel
RV9A-N113SQ
52F
Old 11-22-2021, 08:54 AM
Yes it's true that for RVs in general slips don't alter the descent nearly as much as some other draggier and aerobatic types with larger control surfaces. RVs are rudder limited and don't have a lot of drag to exploit.
Old 11-22-2021, 09:19 AM
vlittle's Avatar
vlittle vlittle is offline
My 9A slipped very well. Full flaps, nose high and FULL rudder for a short field landing. Just before landing, smoothly relax the rudder and push forward on the stick to arrest the descent rate. Creepy feeling pushing forward on the stick to flare, but that's the way it works.
The 9 wing is not like the other RVs. Practice at altitude.
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
