Go Back   VAF Forums > Model Specific > RV-6/6A
Old 08-25-2010, 07:06 AM
Default Show us the status of your 6/6A project!
I am starting this thread since we don't have one already for the -6. I would really like to see what stage other builders are at. There are all of 3-4 active RV-6 builders using Kitlog, so not a lot of reference material.
This thread may also act as a list of builders that can provide guidance to those coming after them. If you just completed a particular stage of the build, you are in a good position to provide advice to someone starting that stage.
Hopefully one of the Mods will see fit to make this a sticky.
To Kick things off:
I am currently working on the fuselage kit. I recently finished (well, mostly finished) riveting the left tailcone skin on and just yesterday started on the right side. All the fuselage skins have been fitted and drilled and most of the countersinking / dimpling of the structure is complete. Once I get these tailcone skins riveted, I just need to fit / drill the rudder pedal assembly and then I can rivet the side skins.
Left tailcone skin riveted (except the radius and overlap joints)
Right and bottom skins clecoed in place so I could mark the bottom skin for final triming of the aft edge. I had a slight misallignment of the skin (didn't have it strapped tight enough when drilled) causing a gap at the aft corner radius. I corrected the gap by straping and drilling out to #30. This worked just fine and still left me with ample egde distance. These are all dimpled for -4 rivets, not "oops" rivets.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 08-25-2010, 09:47 PM
JackW JackW is offline
Default RV6A Build Progress
G'day Colin,
I inherited a 6A which had the majority of riveting complete. Build quality was very good too. I've just sent my engine out to the AP for build so I should be hanging it in about six weeks time. Meanwhile, the panel is mostly complete and I'm just starting on the electrics (using a VP-X to make it simple). Upholstering will happen next week with a visit to the auto trimmer. finish will be basic cow. My website http://tecnet.com.au shows progress. If you look at the panel (under Images) you will not see a radio. It is mounted in front out of sight and is remote controlled from the EFIS. Special prize for figuring what movie is showing...
John Bridges
Riddells Creek (YRID)
near Melbourne, Oz
VH-VNS, RV-6A, IO-320
It flies!
Old 08-25-2010, 10:19 PM
John,
The project is looking great! I like the finish on the panel. Is that an overlay or real CF? I can hardly fathom a guess at the movie, it reminds me of Harts War or Air America.
I was down in your neck of the woods this time last year (well, to the north at least). That is a beautiful country you have there.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 08-25-2010, 11:55 PM
Default Thanks
The panel was originally cut for steam gauges and the Vans map box. Being a cheapskate, I got a sheet of 0.025" carbon fibre from DragonPlate in the US to cover the panel instead of getting another panel. The CF can be moulded to simple curves with a heat gun if you are careful. It is held down with good quality contact adhesive.
Re: The movie; think Steve McQueen...
Thanks for the good rap on our country. I can't think of a nicer place to live myself (and only one hill to run into @ 7,310 odd feet!).
John Bridges
near Melbourne, Oz
It flies!
Old 08-26-2010, 12:32 AM
gasman gasman is offline
Originally Posted by JackW View Post
G'day Colin,
The Movie is ..... THE GREAT ESCAPE! ...................
Old 08-26-2010, 12:38 AM
Default Free Beer
Congratulations! Several free beers (not Fosters which tastes like Bud) will be available on the bar at the Royal Mail Hotel, Spencer Street, Melbourne for you to imbibe.
Cheers.
John Bridges
near Melbourne, Oz
It flies!
Old 08-26-2010, 08:33 AM
jimbower jimbower is offline
Colin, I have one of the (if not THE) longest-running -6A project in the St. Louis area. Life does tend to get in the way. Anyhow, I'm pretty much done with the build. The RV is at my local airport sitting in our chapter hangar, waiting on the hot weather and some family issues to moderate. I'll be glad to help wherever I can.
Jim Bower
Old 09-02-2010, 12:33 PM
db9469 db9469 is offline
This thread is a great idea, Colin! I will post pictures of my progress as soon as I can figure out how.
Old 09-02-2010, 02:39 PM
Talking
This is my first time trying to post pictures so I apologize up front if it's a disaster. My -6 wings and tail are both basically finished. I'm currently skinning the fuselage. Colin and I started our fuselages at about the same time and he's much further along than I am. I have a list of excuses that I won't share at this time.
Old 09-02-2010, 03:06 PM
pierre smith's Avatar
Default Dave...a quick lesson.
Go to www.photobucket.com, or any other host.
Post the picture there from "My pictures", or wherever you have them.
Click on the posted picture and you'll see 4 options. Click on "Direct link" and copy that.
Then click on this page and click on the little yellow picture with the mountains and paste there, just be sure there is not two http:/on the left side of the little box. I usually have to delete the one that shows when you click on the yellow box.
Best,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
