Old 09-15-2021, 03:42 PM
Sawtooth Sawtooth is offline
Default RV-6 Bush Plane
I live in Montana and use my Citabria to access several of the wilderness airstrips here and in Idaho. I’d sure like to have the increased range and speed of the RV-6. What do you think I would need to do to make it capable in the backcountry?
Old 09-15-2021, 05:10 PM
azrv6's Avatar
azrv6 azrv6 is offline
Search Sport Aviation archives for January 2017 article on Ken Asbe's "Bigfoot RV6" starting on page 72.
Name:	Screen Shot 2021-09-15 at 3.08.59 PM.png
[ATTACH]15852[/ATTACH
Name:	Screen Shot 2021-09-15 at 3.09.08 PM.png
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 (http://gobinkley.com)
Sedona, AZ
Old 09-15-2021, 05:23 PM
The first RVs I ever saw were a stock RV-4 and an RV-6 up at Moose Creek, ID.
But I'd suggest removing the pants, installing bigger tires and the larger pneumatic tailwheel. These changes, particularly removing the pants, will slow you down some.
Dave
Old 09-16-2021, 08:06 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Almost none….
This summer I took my -14 to two dozen strips in Idaho, Montana, and Washington state along with a friend in a -9A. I have 6” wheels he has the standard 5”. Unless your intent is the Super Cub Super STOL airstrips the backcountry is attainable in a standard RV. We did not even remove the wheelpants, with that said mine are installed about two inches higher than most.
My only suggestion would be to understand the runway is seldom an issue; however, the areas off to the side can be. If needed just shut it down and get out the towbar.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 750+
2021 Dues Paid
The Dues Paid note is a reminder for me
Old 09-17-2021, 12:00 PM
Default Moose Creek
The Moose Creek airstrip 1U1 is a favorite of mine so if RV-6s can fly in and out of there, that pretty much answers my question.
Thanks everybody,
Sawtooth
Old 10-30-2021, 08:40 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
If you get a -6 (not -6A) make sure the engine mount has the gusset mod at the bottom intersection where the landing gear tubes come into the engine mount, to prevent cracks from forming there due to rough operations. Ask me how I know...
PS. If you purchase one already built, also be sure to check that area for said cracks.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Donated August and November 2021
