As you probably know, Van's recommends a 3-inch squeezer yoke for the RV-12. I own a 2 1/2-inch yoke from a previous project. Do you think I can get by with the 2 1/2-inch yoke, or are there a lot of instances where you need the full 3-inch reach? I do have a rivet gun and bucking bar I can use if there are only a few solid rivets I won't be able to reach with the 2 1/2-inch yoke.
I also own a longeron yoke and Avery C-frame. Has anyone found these useful for building an RV-12?
Thank you.
Thank you.
