Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
Old 09-25-2010, 11:53 AM
sandpiper sandpiper is offline
Default Garmin Service Bulletin for the SL30, SL40, and GNS 480(CNX80)
Is everyone aware of Garmin Service Bulletin 0921 for the SL30, SL40, and GNS 480(CNX80) comm radio spurious emmissions? Deadline for coverage under warranty is 9/30/10.
John Horn (donated for 2020)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
Old 09-25-2010, 12:38 PM
Bevan Bevan is offline
Default Where?
I've searched the garmin website but cannot find any details. Can you point to a reference?
Bevan
Old 09-25-2010, 03:04 PM
Bevan,
Go to http://ctflier.com/ and look under Avionics then General Avionics. You can download it there. It is not on the Garmin website. Nobody flying CT's knew about it and neither did the CT manufacturer.
Living near Garmin here in Oregon I was able to handcarry mine in and get one day turnaround.
Independence, OR
LSRM-A, CFII
Old 09-26-2010, 11:05 AM
breister breister is offline
The upgrade (at least for the 480) is free and can be performed in the field by an authorized service agent, provided the unit was already current.
There are also a number of other service bulletins outstanding. These require sending the unit back and installing a new GPS puck (which they provide).
Old 09-26-2010, 04:36 PM
glenn654 glenn654 is offline
Just got my SL-40 back from Garmin about a week ago. They made the repair on my new comm. I bought from another builder even though the announced period for free repair had passed.
Give Garmin a call, since your comm. is new I'm sure they will repair your for free too.
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 09-27-2010, 09:40 AM
Jim Percy Jim Percy is offline
I'm not able to open the service bulletin PDF on the CT site- says I need to log in to view it and I'm not a member. Can someone please email me a copy?
This is it:
http://www.cubcrafters.com/pdfs/sc/garminsb0921.pdf
Thanks!
From Rosie: The following links taken from a post on Page 4
http://www.flickr.com/photos/garmin/...7624983407147/
http://www.flickr.com/photos/garmin/5057616402/
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 09-27-2010, 03:43 PM
PJSeipel PJSeipel is offline
The one you posted in the cubcrafters link is the correct one; SB 921.
Anyone else have the experience of calling Garmin and being told that yes the SB applies to your radio, but that they will not issue an RMA to an individual, regardless of whether the SL30 is installed in an experimental, that I must go through an avionics shop to get an RMA?
PJ Seipel
RV-10 #40032
Old 09-27-2010, 03:47 PM
Several on the CT forum had the same problem. It seemed to be determined by who you talked to. Those that talked to Frank got the run around. If they talked to Gary like I did then there was no problem.
Independence, OR
LSRM-A, CFII
Old 09-27-2010, 04:42 PM
638RS's Avatar
638RS 638RS is offline
Default Which date is correct?
The original post said the SB expires on 09/30/2010. The SB says the exp date is June 30. 2010 after which there is a surcharge.
Richard
Portland, OR RV-7A
Old 09-27-2010, 05:16 PM
Rev C of the SB says it was extended through 9/30/2010.
PJ Seipel
RV-10 #40032
