Old 03-26-2020, 03:05 PM
AX-O's Avatar
AX-O AX-O is offline
Default Looking for a machine or CNC shop
All,
I designed an air filter adapter for the carbon fiber part I have been working on http://www.vansairforce.com/communit...ght=air+filter
I was going to make the adapter out of carbon fiber also but the fiber does not want to lay nicely. Does anyone have a machine or CNC shop? Ideally I would send the file in and a part would show up at my house, as long as it is not crazy expensive.
I found a few places online that supposedly machine your part as desire but have never used these types of services. has anyone on VAF ever done that?
I have a few different designs based on complexity, material and potential associated cost.
thanks,
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 03-26-2020, 03:11 PM
rocketbob's Avatar
I've got a very similar air inlet on my Rocket. You have to make it with tapered overlapping strips about 2" wide at the bottom. You can sort of see it thru the filler in the pic below.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-26-2020, 03:34 PM
krwalsh krwalsh is offline
Default Cut it in half
Axel-
You?ll have more success if you make this in two halves. Build a joggle into the mold so you can cleco it together and then put a 2? tape over the seam. I did a similar mold for an interesting wheel pant shape:
https://photos.app.goo.gl/RokgHJLPfFk6qHR98
The advantage is you can vacuum bag the half part. If you?re creative with the mold you can make it so the parts are symmetric and get away with a single mold.
Kevin R. Walsh
Cozy Mk-IV
Old 03-26-2020, 03:47 PM
hgerhardt's Avatar
I've had good success with 3dHubs. Much of their machining capability comes via China, but quality is great and price is good too. Gotten several AC prototype parts from them. It's almost funny--you shoot a STEP file to the Netherlands and two weeks later you get a box from China with your parts.
As for your composite layup problem, use twill-weave cloth.
Old 03-26-2020, 03:52 PM
R_Heap R_Heap is offline
Try Andrew at Spingarage, LLC. He's up at L94 in Tehachapi.
https://www.spingarage.com/custom-solutions
He's a good dude and sorta local for you. He might not have the bandwidth to do it, but he has machining capability and this is right up his alley.
Old 03-26-2020, 04:00 PM
AX-O's Avatar
Thanks for the info guys.
I was trying to make this out of one piece. Already made one out of 2 pieces with fractions of cloth. not happy with it. in the quest for learning, I also wanted to try the machine or cnc route.
Who knows, this may turn into a product for other folks.
Thank you again.
Axel
Old 03-26-2020, 06:02 PM
jimpappas jimpappas is offline
Default CNC shop for new inlet
AX-O
Have you given any thought to someone with a 3D printer that could make it?
At Boeing we made some parts that way.
Jim Pappas VAF #13
Old 03-26-2020, 07:23 PM
TFeeney TFeeney is offline
Default CNC access
Axel,
I may be able to help you.
PM with contact info on the way.
Tim
RV10
QB Wings done
Fuselage done
Systems and electrical...
Old 03-26-2020, 07:58 PM
vfrazier's Avatar
vfrazier vfrazier is offline
We make the Wining's airbox for the F1 guys. There's another piece that isn't shown, a tapered tube that connects the filter to the Scat hose that goes to the adapter that mounts on the servo.
RVs wouldn't use the external scoop.
Blake sells the adapter here:
https://www.flyboyaccessories.com/Fu...ter-p/2103.htm
I couldn't see Rocketbob's photo for some reason, but he helped Jim with his original scoop and molds.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 03-26-2020, 08:27 PM
rleffler's Avatar
rleffler rleffler is offline
Originally Posted by AX-O View Post
All,
thanks,
Talk with Geoff at aerosportproducts.com. Geoff?s main business is Aerosportmodeling.com.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
