  #11
Old 05-13-2022, 10:44 AM
rvbuilder2002's Avatar
Originally Posted by ERushing View Post
The manufacturer's documentation for this flap motor leaves a bit to be desired...
The thick wires are flap motor power. The thin wires are for the potentiometer. Yellow is power. Red (or Blue) is signal. White is ground.
Hope this helps!
Eric beat me to it.
The supporting engineering dept. just provide the following and I believe work is being done to incorporate it into the install documentation.
Name:	Screenshot 2022-05-13 094113.jpg
Scott McDaniels
Hubbard, Oregon
Van's Aircraft Engineering Prototype Shop
FAA/DAR
Old 05-13-2022, 02:12 PM
ColoradoSolar ColoradoSolar is offline
Eric beat me to it.
Scott and Eric thanks for the info, exactly what I was looking for. I had figured out the main motor wires but was unsure which wires were what for the pot. I'm glad Vans came out with this new motor, I was going to install the ph aviation one but having the mount already redesigned is easier.
Eric Vickery
RV-6A Tip-Up Bought Flying
RV-10 #42451 Empennage complete (except fiberglass)
Received Fuselage and wing kits
Old 05-16-2022, 04:03 AM
TASEsq TASEsq is offline
Anyone know if there are any plans for updated brackets to accept this motor in the -14?
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 05-22-2022, 04:15 PM
raabs raabs is offline
Default Does retrofit kit come with the flap motor?
Or is it a separate item that I need to order? Would like to replace the old style.
Thanks.
Rob Kelly
RV-10 Under Construction
Old 05-23-2022, 06:20 AM
Dad's RV-10 Dad's RV-10 is offline
Originally Posted by raabs View Post
Does retrofit kit come with the flap motor? Or is it a separate item that I need to order? Would like to replace the old style
ES-FA-PA-450-12-5 is the flap motor.
Old 05-23-2022, 01:26 PM
Thanks Dad.
But does the new flap motor come with the retrofit kit or is the retro kit something additional I need to get?
Rob Kelly
Old 05-23-2022, 02:09 PM
jacoby jacoby is offline
Thanks Dad.
go here: https://store.vansaircraft.com/10-fl...rofit-kit.html
click on "kit contents" and you'll see the motor is included.
Old 05-24-2022, 06:15 AM
Thanks! Only saw the motor by itself before.
Rob Kelly
Old 05-24-2022, 06:20 AM
I thought that's exactly what I posted in the image??? Oh well.
