Old 05-17-2022, 04:53 PM
gttice gttice is offline
Default What are folks using for "smiley" filler
Based on my search results, either I am terrible at finding the right search term or I am the only person to have ever created a smiley that needs to be covered up. But in case there is anyone out there that has used a filler for other kinds of dings, I would love to know what you think are the better ones.
Jerry T.
Old 05-17-2022, 04:57 PM
wirejock's Avatar
wirejock wirejock is offline
Default Filler
Depends on why and where.
I've plugged holes in pull rivets with JB Weld for cosmetic purposes. I've covered or repaired other spots with flox. Never tried to fill a smiley because I don't make mistakes!
Joking of course. If the smiley is on the aluminum and will be painted, I would use auto glazing compound. Sands flat really easy. High build primer would probably fill easily. You may need to sand the smiled first. There's usually a raised area. Not sure how I would know that!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 05-17-2022, 05:31 PM
Foghorn's Avatar
Foghorn Foghorn is offline
Jerry,
Donít search on the forum. Youíll never find anything. Instead use your favorite search engine, I prefer DuckDuckGo. Type in what youíre looking for followed by ďsite:vansairforce.netĒ. Youíll find all the threads that way.
Example: smiley filler site:vansairforce.net
I used rage gold on the smileys that were bad enough for filler. Thankfully just a few spots.
Good luck
Jeff Parker
RV8 Fastback (Tomís Dream) - Phase I (N767TS)
C195 (Red Dawg) - Flying (N4469C)
Retired Army CW4 - Helicopters, KingAirs, B737, MD11
Old 05-17-2022, 05:43 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Use this
Most "smiley's" are pretty small. Scuff them with 320 paper, clean with alcohol. I personally use Evercoat 416 glazing compound for any small fills and finish fill. Hard yet sands like balsa wood. (I didn't have any mistakes on my second 7)
General rule of thumb, anything with a depth of 1/16" or more should be micro filler and epoxy. 1/16th or less, Rage or 416.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717AZ Painted and Complete
2021 Outstanding Workmanship Sun N' Fun
2021 Gold Lindy Grand Champion Kit Plane
2022 Copperstate Fly in Grand Champion/Best Metal
2022 Reserve Grand Champion Sun N' Fun
Old 05-17-2022, 07:29 PM
Stoo Stoo is offline
I prefer to use Superfil which is an epoxy filler. I think this is more stable over the long term. Polyester fillers tend to shrink.
Stewart Willoughby, 6
Old 05-17-2022, 08:47 PM
Bandera Bandera is offline
For bigger dings like a hail dent I like Evercoat Rage or Rage Gold. For smaller dings or scratches I like Evercoat 417. After sanding the filler I prime the spot with PPG K36 primer.
Old 05-18-2022, 06:28 PM
RV7Guy's Avatar
Default Not Catalyzed
Catalyzed fillers don't shrink. Something like Stanton in the tub will shrink.
Epoxy and micro works but difficult to get that perfect feathering blend. The 416 works great for this.
Darwin N. Barrie
Chandler AZ
www.JDair.com
Old 05-19-2022, 11:56 AM
gbitzer's Avatar
gbitzer gbitzer is offline
I've had 20 years of good luck using 3M™ Urethane Seam Sealer to fill overlapping panel lines and even hid hard rivets on my RV-6. This stuff is easy to use, doesn't shrink and remains flexible. Can be thinned and blended using reducers. Available at most auto body paint stores. It's very paintable after curing.
Greg Bitzer
RV-6 / 180 CS
BE36 Bonanza
DragonFly Tug
Airwave Pulse Hang Glider
PW-5 Glider
STEM RV-12is Building Mentor
Stoney Point Field - 6GA0 Atlanta, GA
2022 VAF Dues Paid
Old 05-19-2022, 02:31 PM
MarkW's Avatar
MarkW MarkW is offline
I can't believe you would cover a memory like that.
I use a sharpie to write the name of the person that was bucking during that session. On the inside of coarse.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 05-19-2022, 04:56 PM
I donít know how many times Iíve heard ďCan you do something about those? My wife was helping me rivet that dayĒ. Yes sir, sure can. Lol
