w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 03-18-2023, 06:32 PM
Bavafa Bavafa is offline
Default Garmin Transponder fault
My friend came to visit me and during the flight, his transponder, a Garmin 45R, was not working.* On the ground, it is showing "Transponder Fault '' on G3X right above the squawk*code.* We could change squawk code and he said his ADSB was working fine as he could see traffic.* Power cycling*did not do anything and we checked the wiring at the transponder and all looked to be OK.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Old 03-18-2023, 08:52 PM
Chipper G Chipper G is offline
Been dealing with this as well. Take it to a garmin shop and have them update the software unless you can do on your own.
Old 03-19-2023, 08:38 AM
Curious to learn more about your situation? Was yours working and all the sudden got the "transponder fault"? And did the software upgrade fixed it?
Mehrdad
Dues paid
Old 03-19-2023, 08:45 AM
mburch's Avatar
mburch mburch is offline
You may be able to see more detailed status information about what is wrong with your transponder, if you look at the System Information page under Tools-->Diagnostics in the main menu, or in config mode.
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
Any opinions expressed in this message are my own and not those of my employer.
