Has anyone experienced water ingress into sensenich propellor blade. Parking outside on ramp for a few months, and went to check the oil, and heard sloshing sound. put the sloshing blade vertical, and about 5 ounces of water dripped out over a couple of hours from inside the hub. I don’t remember what the hub end looks like but there must be a small hole somewhere into the void inside. I am guessing that this does not do anything good for the balance of the propeller until all the water is out. I think that I got the vast majority out but there must be some drops left inside. not sure how to dry it out.
