G3X fuel quantity calibration - is it possible to swap left and right tanks?
kaa
Long story short, I didn't check that I routed the fuel sender wires correctly, so left and right indications are swapped now. I already calibrated them, so I'm wondering if
  1. it is possible to just swap the left and right indications in software (basically rename left to right and vice versa)
  2. input calibration tables manually without actually draining the fuel. In this case I could swap the wires and just retype the calibration
I looked in the manual, but didn't find anything.
Thanks!
