Echo uat sky fyx
Charles in SC
I am having an issue with my adsb. I have tried to get an answer from the maker by phone call and two emails.
My unit transmits the wrong tail number. My tail number is N402CL but it transmits N402CE. I have gone through the setups several times to be sure it is correct. Any ideas would be appreciated.
Thanks in advance!
If you haven't already....put your cell phone in "airplane mode" (cellular off) before you connect to the Echo wifi to configure the unit. I've had outstanding customer service from Uavionix, I bet they will help.
What does your ICAO code in the set-up say?
For N402CL it should say A4B44C.
For N402CE it would say A4B446.
You want A4B44C
Thanks in advance!
Any resolution on this issue, as a uAvionix QI it would be good to know.
