Old 09-26-2019, 10:00 AM
edward7048 edward7048 is offline
Default ign. problem
lately when I start the engine during warm up I have a slight miss but
after the engine gets above 120 deg. oil temp. and I start increasing power
for mag. check at around 3300 rpm the engine runs very rough on both
mags. I have to go to very high rpm to make the engine run some
what less rough but have to go take power to make it to run ok. Has any
won had this problem?
Old 09-26-2019, 10:10 AM
Default ign problem
I for got to say that I had installed new plugs and it did not help.
Old 09-26-2019, 10:24 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
How many hours on engine? I just rebuilt both carbs - see... http://www.vansairforce.com/communit...d.php?t=173080
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 644
Old 09-26-2019, 10:35 AM
NinerBikes NinerBikes is offline
How soon do you turn off the choke, during warmup? 30 seconds, a minute, or? If it hasn't been done, I'd say rebuild the carbs, too. Do you run a lot of Mogas with ethanol in it, or 100LL?
Old 09-26-2019, 07:49 PM
Default ign problem
The engine has about 200 hours on it, the carbs were rebuilt by lockwood
two years ago. I burn 93 oct with eth. I release the chock as soon as the
engine comes out of retarded spark
