exhaust hangers on 8A, IO-360M1B
Alan Erickson
Active Member
Folks, I can't quite figure out where to put the exhaust hanger clamps on my Vetterman exhaust in my 8A with an IO-360M1B (before you rush to answer, note that it seems quite different both from -8 and from IO-360A). There seems to be no place on the exhaust at or behind the sump which has a flat spot the width of the clamp on both sides, so Larry V's diagram goes out the window. Any photographs lying around out there you can help me with? Thanks!
