Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 12-30-2020, 07:26 PM
macflyer macflyer is offline
Default HELP! ARINC, Garmin GPS 175 GRT Horizon Set up
I'm trying to set up my 10.1 GRT Horizon, ARINC 429 and the Garmin GPS 175. I believe I have everything installed correctly, but I do not get the MAP on the Horizon to come up? It is simply black. Can someone give me the configuration setting I need for the Horizon and the Garmin GPS 175 to communicate with each other?
Thanks for you help!
N661RV
RV 6
Steve McIntosh
Old 12-30-2020, 07:42 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
It might help if you tell what you have done so far----wiring and config stuff.
Dont forget that the GRT serial ports have more than a single layer for each port. Baud rate is buried under the port assignment IIRC.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-30-2020, 08:20 PM
Lots of possibilities. I'd start by making sure the map data is loaded in the Horizon. If not, download it from GRT web site onto a memory stick, then transfer to the Horizon.
I think the RS232 out (on the gps) and in (on the Horizon) should both be set to format 'Aviation', and baud speed '9600'. For full functionality you'll also need the ARINC hooked up but I *think* the RS232 connection should get you the GRT moving map.
Old 12-30-2020, 09:09 PM
Hi Bob,
I need to get out to the airport to check all the settings. The ARINC is hooked up and I am getting readings on the Horizon counter in the set up menu. The GPS 175 I believe is configured correctly. The Horizon says I have Map data loaded, but can reload again. Thanks for your help!
N661RV
RV 6
Steve McIntosh
Old 12-31-2020, 11:37 AM
Black map means no map data. Double-check you've got the map database properly loaded - it will show up in the boot up screen and is also accessible from the set menu. No version/date information would indicate no map data loaded.
Arinc 429 data is absolutely NOT needed for the GRT map function to work. Do you have the GRT GPS puck installed? If so, configure GPS2 as that "internal" GPS and set the Horizon to use GPS2 as its position source. This should bring your map up independent of any connection to the Garmin navigator.
Old 12-31-2020, 12:50 PM
Here is my Config for the GRT Horizon. I do not have the GRT puck. I was going to depend on the Garmin to provide the GPS info.
ARINC MODULE CONNECTED: YES. Port 2
ARINC RECEIVE RATE: Low
ARINC TRANSMIT RATE: Low
Serial port 2 setup
Rate:9600
Input: GPS 1 Aviation/Map Com
Output: Fuel/Air Data
Garmin 175 Config
Format: EFIS/ADC
Format: GAMA Format 1
Speed;Low
SDI: LNAv1
Thanks for your help!!
N661RV
RV 6
Steve McIntosh
Old 12-31-2020, 04:16 PM
I have a 420W, not a 175. And I am not at the airport. But I *think* the gps RS232 out format is set to ‘aviation’, not efis.
Old 12-31-2020, 04:27 PM
Default Thanks
Thanks, I will try "Aviation" on the Garmin 175. Do I need the puck from GRT? I thought the Garmin would supply the GPS info for the Map to work. The navigation base is loaded into the GRT, but the Map is black? I changed the color, but still black.
N661RV
RV 6
Steve McIntosh
Old 12-31-2020, 04:32 PM
If you designated the Garmin as a gps for the grt it should work. Mine uses the 420 first, and reverts to the gps in my Skyradar if the garmin is off.
Old 12-31-2020, 04:36 PM
Where do I designate the Garmin at? I thought the ARINC once hooked up and working would push the GPS signal to the GRT Horizon?
N661RV
RV 6
Steve McIntosh
