Old 03-31-2014, 10:58 PM
lr172 lr172 is offline
Default Flight Training in NW Chicago
I am building an RV-6A and hope to be in the air by this Fall. I have not flown in several years, so need some training to knock the rust off and regain my competence this summer. I live near Schaumburg (06C), but Dupage and Palwaukee are easy as well.
I am looking for a good instructor in my area. I would love to do this in a trainer's RV, but figure that may be unrealistic. I can either rent the instructors aircraft or use the local rentals.
I found an a gentlemen for my transition training and first flight, but definitely need some more basic training to re-build my skills first.
Thanks for any suggestions you have.
Larry
Old 04-01-2014, 02:34 PM
BobTurner BobTurner is online now
Originally Posted by lr172 View Post
I would love to do this in a trainer's RV, but figure that may be unrealistic. I can either rent the instructors aircraft ...
Larry
Not just unrealistic but in general not legal. An RV owner offering his aircraft for rent for transition training will have a waiver ("LODA") allowing him to do this - but the waiver is generally good only for bona fide transition training, not "knocking the rust off".
Plan to rent a normally certified airplane to get current (including a Flight Review). Then go to transition training.
Old 04-01-2014, 04:18 PM
JPalese's Avatar
JPalese JPalese is offline
Default CFI
Direct email sent
John Palese
1) AAL Captain & Check Airman (ret)
2) USAF LtCol & Command Pilot (ret)
Active:
1) ATP / CFII ASME
2) Adjunct Professor-Aviation Science
3) MKE FSDO FAAST Lead Rep & Remedial Trainer.
RV-12 Transition Training, Rental & Instruction.
RV-6/6A, RV-7/7A, RV-9/9A transition training
RV-7 Transition Training LODA.
Drone Detection & Counter-measures
DE WB9JPH
<IXOYE><
www.facebook.com/rv12wi
www.facebook.com/rv7wi
http://www.terravigilis.com
Old 04-01-2014, 07:43 PM
jimpappas jimpappas is offline
Default training
Justin Cleland, CFII
Galt Airport 10C
Greenwood, IL
Just North of Woodstock but worth the trip.
Justin is a great instructor, tell him I sent you.
815-648-2433
Rosie called it the "coolest old airport I've ever seen".
There are even a couple books about it.
My hangar and RV were there and took lessons from Justin.
Jim Pappas VAF #13
Old 04-01-2014, 10:59 PM
Mark C. Mark C. is offline
Larry, I sent you a PM about training.. I trained at both 06C and DPA.
Mark C. RV9A 119RV
