Old 01-03-2021, 04:27 PM
JackZ JackZ is offline
The spar is the same on the 7 and 9 except for its length. Torque a bolt with a stubby wrench some day and then do it with the longer wrench. You will soon see that you can exert far more torque with the longer wrench. Itís the same with the wing. Any lift created at the end of the 9 wing exerts far more twisting action than the shorter wing of the 7.
The 9 wing is designed for efficient climb and higher altitude cruise speed. I love mine for cross country. I will maybe try to get some aerobatic training in my next plane Rans s21. Itís rated at 6 g. A very experienced pilot, whom I trust implicitly regarding aero, told me to get aerobatic training in a far less slippery airframe than a vans rv.Iím taking his advice.
Old 01-03-2021, 04:38 PM
ChrisHodgens ChrisHodgens is offline
Thumbs up
That is sound advice!!!
Old 01-03-2021, 07:23 PM
ty1295 ty1295 is offline
So with that said, just arm chair thinking I wonder if someone could do a clipped wing 9. HMMMM...
Jeff Scott
RV9A First Flight 9/30/19
Old 01-03-2021, 07:29 PM
scard's Avatar
scard scard is offline
Sure! It has been done. It is called a -7 with a different horizontal stab. .
Scott Card
CMW E-Lift
Old 01-03-2021, 08:28 PM
And wing airfoil.
Jeff Scott
Old 01-04-2021, 01:50 AM
grubbat's Avatar
grubbat grubbat is offline
Default Wing tips
You could remove the big wingtips and put end plates on and save some wingspan but anything more would be extensive because the flaps and ailerons would have to be shortened. The wingtips have some efficiencies built in with those outer tips moving the wing vortexes away so you may end up with no net gain. Who knows.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 01-04-2021, 10:40 AM
Steve Melton's Avatar
Default no aerobatics
like others I've been temped to do aerobatics in the 9 but so far I have resisted. no rolls or loops. I hope I can continue to resist. if the 9 had been designed for aerobatics I would do them but since it was not I don't. simple as that.
Steve Melton
Cincinnati, OH
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 01-04-2021, 10:58 AM
jjbardell jjbardell is offline
Just to throw a log on the fire.
The 9 cannot do advanced aerobatics, but you can roll just about anything...RV9A or a Boeing 707 if you stay at 1G. The plane doesn't know up from down as long as you maintain that 1G. The 9A has a better roll rate than a lot of airplanes which are rated for aerobatics.
Just sayin'...
3.2.1...begin flaming.
https://photos.app.goo.gl/h8feirnUvasoByGB9
https://photos.app.goo.gl/SvYPfa72QEboQR9J8
Cheers, Josh
Building - Zenith 750 [11323] CruzerDuty27.5
N67LJ RV9-A [90504] - SOLD
N83LJ Sonex [0864] - SOLD
https://rvpilotlife.wordpress.com/blog/home/
Old 01-04-2021, 11:09 AM
Just sayin'...
I fully expected this.
Steve Melton
Cincinnati, OH
Old 01-04-2021, 01:01 PM
Mel's Avatar
Mel Mel is online now
If I had an RV-9 and I wanted to do acro, I would certainly put it on a video for my Insurance company to see. It would probably help with my rates to show how good I fly.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
