Old 10-06-2020, 07:27 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
Default Filling hole for step
What's the best way to fill the step hole. I'm building an RV8 not an A, I didn't realize the skin would have the step hole in it.
RV6 N7219d
IO-320-B1A
Sam James cowl
first flight May 2, 1997
RV8 #83830 tail done, wing done, fuselage done.
Working on the finish kit.
Old 10-06-2020, 07:51 PM
scard's Avatar
scard scard is offline
Just a basic sheet metal patch. Fair it with some proseal.
Scott Card
CMW E-Lift
Old 10-06-2020, 08:08 PM
Thats what I was thinking, I just wanted to check. Thanks
RV6 N7219d
IO-320-B1A
Sam James cowl
Old 10-06-2020, 09:01 PM
rapid_ascent rapid_ascent is offline
Just to clarify, was a step installed previously?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-06-2020, 09:30 PM
There wasnít a step installed, Iím just now building the fuselage.
RV6 N7219d
IO-320-B1A
Sam James cowl
Old 10-06-2020, 10:19 PM
Desert Rat Desert Rat is offline
Is it just a #40 hole that show you where to cut out for the step? If so, the plans call out to just dimple it and install a rivet to nowhere. At least thatís how it is on the 7
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 10-06-2020, 10:20 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
There is a fairing panel that installs over the opening so it will be covered on an -8. No need to manufacture a cover plate. The fairing gets installed after the wings are on.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Old 10-06-2020, 10:50 PM
Thanks for the information and the picture Carlos, I won't worry about it then.
RV6 N7219d
IO-320-B1A
Sam James cowl
Old 10-07-2020, 07:10 AM
scard's Avatar
In the -1 RV8 kit, that skin comes with the huge hole already punched in it.
Scott Card
CMW E-Lift
Old 10-07-2020, 07:42 AM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Install a step! A friend of mine bought a gorgeous RV-8 that has a step installed by the original builder. At first I thought it looked a little weird, but I must admit it sure is convenient for height challenged or aged individuals. Iíve given rides to many people that have found the transition from ground to wing a bit difficult and would welcome the step.
Jerry Esquenazi
RV-8 N84JE
