Old 09-26-2020, 10:32 AM
Foghorn's Avatar
Foghorn Foghorn is offline
Here's a possibility.
https://turb.aero/product/ta200tp-turboprop-engine
Jeff Parker
RV8 Fastback - Building (N767TS)
C195 - Flying (N4469C)
2020 dues paid
Old 09-26-2020, 11:52 AM
Sibirsky Sibirsky is offline
Originally Posted by Foghorn View Post
I have seen this one as well , 200HP is a little underpowered for an RV10 isnít it ?
Old 09-26-2020, 07:51 PM
David Z David Z is offline
Default 210hp
Originally Vans had a 210hp engine option. Continental IO-360 6 cylinder engine. As I understand it, that engine option wasn't very popular, so they dropped support. A 200hp turboprop, is probably quite comparable to a 210hp piston engine. It probably takes more than 10hp to overcome cooling drag that's absent with a turboprop!
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage started
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 09-26-2020, 08:08 PM
Foghorn's Avatar
I was thinking it would be great for a 7/8.
Jeff Parker
2020 dues paid
Old 09-26-2020, 08:46 PM
RV10Pilot RV10Pilot is offline
You will spend more time and effort FWF than assembling the rest of the 10.
Old 09-26-2020, 08:58 PM
Default ...and
...and likely more $$$$
Bob
Aerospace Engineer '88
RV-10
Phase I as of 12-02-2020
Dues+ Paid 2020,...Thanks DR+
Old 09-26-2020, 08:59 PM
emsvitil's Avatar
emsvitil emsvitil is offline
https://www.rolls-royce.com/products...rboprop.aspx#/
Ed
Old 09-27-2020, 05:25 AM
cderk's Avatar
cderk cderk is offline
That 210hp is installed in their demonstrator that I used for my transition training back in March. Granted there were only two of us in the plane, I felt like it performed really well. We didnt do a cross country or load it up with people, but it seemed like there was certainly enough power there.
RV10
First Flight Apr 6, 2020
Old 09-27-2020, 08:40 AM
10builder's Avatar
10builder 10builder is offline
Default Do Your Homework
I wouldn’t dissuade anyone from building what they want, but as you take this journey be prepared for the challenge with insurance. Paul posted this great video in another thread: https://youtu.be/cVNqmE33NTU
Brian S.
Arrington, TN
SPA Panther N87XP
RV-10 N104BS (Sold)
2020 VAF donation cheerfully submitted!
Old 09-27-2020, 05:28 PM
terrye terrye is offline
Greetings ,
I found an RV Kit that I am willing to purchase next week or so ,
I was wondering if there are any alternatives to the expensive PBS TP100 engine?
I appreciate your input and advice .
Regards
Toufik
You should read the Kitplanes article on the turbine RV-10 very carefully.
https://www.kitplanes.com/turbine-powered-rv-10/
Compared to the standard Lycoming IO-540 the turbine is a much more expensive engine, much thirstier engine (climb and cruise) and thus less range, custom engine mount and cowling, no faster.
Not sure what the attraction is unless you just can't get Avgas or Mogas.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
