G3X Touch Reference Speeds not showing
supik
My G3X Touch Reference Speeds disappeared, they used to be located below the speed tape when on ground.
I'm not flying yet, but when I engage the DEMO mode, the speeds are being displayed. ..not in normal mode
-any ideas?
V Speeds
-any ideas?
Igor,
Is your airspeed tape registering an airspeed, rather than "--"?
Justin
Justin,
here is a picture before and after. Speed indication seems normal.
The G5 displays the Ref Speeds normally.
Igor,
Justin
Here is a better picture with the speed tape missing REF Speeds
You should not be reading an airspeed on the ground...
Correct, but he should be seeing the V-speeds stacked up along the right side of the airspeed tape...
Igor -- did you plug in the V-speeds as per the installation manual, revision AN pages 35-115 -- 35-117?
G5 shows - - dashes
