I hesitate to interject reality into these sorts of conversations, but in the spirit of productive discourse, I suppose I should offer up the real world observation that climb rates in the RV-10 are often limited by the ability to reject heat. Cooling seems to vary from one aircraft to another, but I doubt that any stock RV-10 is capable of a sustained max power sea level climb at Vy under adverse conditions, i.e. very hot weather. It appears that many can not perform a sustained max performance climb in any sort of warm weather. Not a big deal for the most part, drop the nose a bit, lose a little bit of climb but pick up speed and cooling air, and you are good. But with regards to this conversation, adding more horsepower to the airframe will only buy a higher climb rate if modifications are made to increase cooling. In cruise, the increased cooling drag will result in an airspeed penalty, unless you engineer a variable exit. Thinking about how airspeed scales with power and drag, you could end up with an airplane that doesn't perform any better than a stock aircraft.
