wing edge alignment?
prkaye
Question - is the outboard edge of the wing (the metal part) perfectly parallel to the aircraft centerline? I'm asking because I may mount a magnetometer in the wingtip and I want to be sure i use a correct reference line for aligning it.
It seems to be. I mounted my magnetometer in the left wingtip using the garmin mount and it has worked well.
Awesome, i've just ordered that mount and will probably mount my magnetometer in the fuselage with it.
Thanks!
Actually, I'd appreciate any advice from folks on where is the best location for my Garmin magnetometer. Wingtip, fuselage or tail?
