Old 07-17-2022, 08:25 AM
jaradtke's Avatar
jaradtke jaradtke is online now
Question Hartzell Governor
How much travel should you see on the prop control vernier knob?
Jeff Radtke
Lutz, FL
RV-7A - SOLD
RV-7A - New Build
Tail Feathers - Complete
ER Wings - Complete
Fuselage - Complete
Finish - Started
Old 07-17-2022, 12:02 PM
rvsxer rvsxer is offline
Mine is a Hartzell S-1-10 and the full travel is 1.25". The cable is attached to the furthest out hole in the governor crank arm. Works great.
Also, this governor won't govern below about 1800 rpm so don't be concerned if it's not working and you are below that.
Mike Hilger
RV-6 N207AM w/G3X, 1,800 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 07-18-2022, 07:13 AM
lr172 lr172 is offline
This will depend upon the length from the pivot center to the center of the attach point hole on the governors arm. Shorter distance = shorter cable travel, stop to stop
Old 07-18-2022, 07:39 AM
jaradtke's Avatar
Granted. However, my S-1 has only 1 hole in the control lever, so it has a fixed geometry. The only variable should be the maximum RPM adjustment screw, which is a +-3/8".
Jeff Radtke
Lutz, FL
RV-7A - SOLD
RV-7A - New Build
ER Wings - Complete
Fuselage - Complete
Finish - Started
