  #21
Old 07-05-2022, 09:21 PM
pv9 pv9 is offline
Thank you so much. That was fortunately not Teflon. It was approved permatex fuel sealant. Now the hard part of relocating the fuel flow transducer.
Donated Feb 2022.
Old 07-06-2022, 05:26 AM
Jerry Fischer Jerry Fischer is offline
Default Fuel Smell
Don't fprget to check the airbox for the drain holes that don't always get drilled during construction. See Vic Syracuse' column on this issue in the forums.
[b]Jerry Fischer
VAF# 1646
Tech counselor
Old 07-06-2022, 07:55 AM
Flyjon57 Flyjon57 is offline
pv9,
I sent you a PM.
Let me know if it makes sense.
Jon
Old 07-06-2022, 09:25 AM
pv9 pv9 is offline
Thank you all so much. I have located the smell to the fuel vents that are pretty close to the exhaust ramp. The exhaust ramp has some cracks that are stop drilled (common problem on the 8A it seems).
After landing with a hot engine the vents have a pretty strong fuel smell that makes its way into the cabin.
Donated Feb 2022.
Old 07-06-2022, 09:56 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Remember you have blue stains on the floor near your rudder pedals. This is only a result of a fuel leak.
The exhaust ramp does need attention as it could be a source of Carbon Monoxide into the cabin. Pro-seal is a good option to seal it up.
Carl
