Looking for install and torque setting for auto plugs and the adaptor.
EFII instructions say put the plug in the adaptor then torque the spark plug while in the adaptor to 30 lbs to set both the plug and adaptor.
EMag instructions say plug into the adaptor and then 18 lbs torque applied to the plug.
I have also read, plug in the adaptor, torque plug at 18, then torque adaptor at 20 lbs
I get the plug into the adaptor and then torque the plug in the adaptor, but big point spreed between 18 and 30 lbs.
So what is the tried and true method.
I’m installing Denzo spark plugs with a Surefly ignition and an auto plug harness set.
