Long story short, I didn't bend the elevator AND the trim tab aggressively enough along the relief holes, so they interfere if I were to install them. I probably need a collective fat quarter inch.
An experienced serial builder suggested attempting to smash the bends a bit more aggressively with a mushroom set, but I'm concerned about wrinkling the skins around the bends.
I have seen people cut the ears off, fabricate riblets, face the web of the riblets into the trim tab and elevator, and squeeze some solid rivets around the edge. That seems easy enough, the downside being the unsightly gap between the tab and the elevator (is this an operational issue, or just a visual issue?).
Van's builder assistance suggested a wacky third option, to chop the ears off, score the insides a bit, then use spray-foam (like the stuff you use on your house to seal holes where pipes come through the foundation) to form the "rib", and put some sealant (epoxy?) over the ends.
Any suggestions from experience?
