If I had to do it over again - would not get the full leather side panels (Classic Interiors) again. They take up too much room in our 9 as nice as they are. Wife and I are not big, but not small either, so I guess that is relative. The tonnouea cover is awesome - keeps everything out of the sun and sight. On that note, would probably get the heated seats option next time.
Would not use the junk fresh air vents from Vans - they leak big time and in our weather (Alberta) are more than annoying. Will be updating that this spring.
Would not be without our Reiff pre-heaters. Have the cylinder bands, 2 oil sump and 1 oil cooler heaters - 1.5 hr plugged in and oil temp is 70 - 85 before startup. Unheated hangar and about 20 outside.
Two changes on the sticks switch - I would like the flap control on the stick and a PTT on the passenger side as well. No big deal - we bought it built, unpainted, no interior and couldn't be happier. (Thanks Troy
