Old 08-13-2018, 09:18 AM
dmat dmat is offline
Default Relocation of Panel Brace? RV6 Tip-up
In the process of upgrading to a g3x(non-touch) and it looks as if the panel brace is getting in the way of the screens. I search the forums but couldn't find any info on how anyone relocated the brace(s).
Anyone do this before?
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 08-13-2018, 11:00 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Panel Brace
On my RV6 I moved the LH panel brace a couple of inches to the right to clear a Dynon D100. The brace doesn't align with or connect to the forward deck rib behind the sub panel. I didn't add any other reinforcing and it is still solid after 200+ hours.
Jim Sharkey
Rv6
Jim Sharkey
RV6 YO360-A1A
Flying Since 2009
Old 08-13-2018, 11:22 AM
BillL BillL is offline
D
D, I had the same issue on my 7 tipper. that sub panel is in three pieces and lousy stiffness - (eyeball FEA evaluation). I might suggest an angle all along it's bottom edge for stiffness. Riveted of course.
I offset/angled the panel stiffeners with lots of little pieces for modification until they were pretty stiff. It worked for me and find that I grab the panel a lot getting in.out and under the panel maneuvers for changes/debugging. I'll post a pict if I can find it.
Bill
RV-7
Lord Kelvin:
I often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.
Old 08-13-2018, 01:17 PM
Zero4Zulu Zero4Zulu is offline
I used 1/2 dia. aluminum rod. Milled the ends 13.5 degrees parallel, drilled and tapped 10-32 holes in each end. Installed in line with the forward ribs. They at the upper edge of the panel and angle downward to be below my tip up canopy brace (when closed) and screwed to the sub-panel and ribs. Solid at a rock and no problem grabbing the top of the panel when climbing out.
Steve S.
Rebuilding RV6A
Scio, OR
EAA Ch. 292
