Old 12-19-2020, 09:51 PM
Andrew Anunson Andrew Anunson is online now
Default One Magneto, One EI
I have heard that running one magneto, one EI is hard on the mag because the EI runs with advanced timing and the mag does not. Is there any truth to this?
Old 12-19-2020, 10:40 PM
JDeanda JDeanda is offline
Default Hard on the Mag??
Huh? I've been to two county fairs and a goat race and I've never heard such a thing. We run a LightSpeed Plasma III ignition and a Slick mag on our RV-6 and neither has ever missed a single spark.
Old 12-19-2020, 11:13 PM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Iíll second that. LSE Plasma II EI with one Mag. No issues for 1200hrs.
RV-7 Flying since 2004
1,100 hrs+
Old 12-19-2020, 11:21 PM
Papa Papa is offline
Same for me...one LSE and one mag...works great. I suspect the EI does all the heavy lifting, when I do a mag check on run up, I get a 50-75 RPM drop with only the magneto selected, but no RPM drop when only the EI is selected. For practical purposes, the magneto is really just backup if the EI fails.
Old 12-20-2020, 12:41 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default doesn't know
The mag doesn't know that the EI just sparked the fuel - it just keeps sparking.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-20-2020, 03:36 AM
Captain Avgas Captain Avgas is offline
No truth whatsoever. The smart money is on one EI and one magneto...best of all worlds.
Youíre only as good as your last landing
Bob Barrow
RV7A
Old 12-20-2020, 03:56 AM
pierre smith's Avatar
Default Yep
12 years on the RV-10 and the EI sure makes for easy hot starts...
Regards,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 12-20-2020, 04:34 AM
plehrke's Avatar
plehrke plehrke is offline
How does the mag get any feedback from EI firing? I donít see a feed back mechanism since all a mag knows is the drive gear is turning.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 12-20-2020, 07:49 AM
sam@riddlehill.com sam@riddlehill.com is offline
So, if I may speculate for my own educational purposes...the timing of the mags is not the same, there is no synch mechanism, no feedback between the mags is required. (Thanks to RV8CH) I’m thinking that doesn’t matter due to the fact that when flying low, the sparks are in synch, and at altitude the slick has fired into a cylinder that has already been fired by an “advanced” spark from the lightspeed, thereby making the slick mag spark no harm/no help? I would also assume that the one slick mage is an impulse type, so as to not to interfere with a smooth start? (This is likely basic stuff..I’ve been out of the recip world for i while).
Sam
SEMO
Emp. complete
Waiting on RV-8 QB Fuse/Wing
currently (over) analyzing the options.
2021 donationÖcheck
Old 12-20-2020, 02:42 PM
Originally Posted by sam@riddlehill.com View Post
? I would also assume that the one slick mage is an impulse type, so as to not to interfere with a smooth start? (This is likely basic stuff..Iíve been out of the recip world for i while).
Most Lycoming engines are set up to start on one ignition only, so most owners choose to start on the EI and use a non-impulse mag on the other side, grounded out during start.
