Old 07-27-2020, 03:16 PM
DylanRush DylanRush is offline
Default Insane to buy a Garmin 155XL?
I currently have an Apollo GX55 in my panel that is essentially useless as it will stop receiving database updates this year. I also have a Dynon Skyview Touch, an ILS and a single COM, and a GRT mini-X EFIS.
I want to be able to fly GPS approaches but I don't necessarily need WAAS. I'm never going to fly down to those minimums intentionally and I have ILS if I really need to.
I see a Garmin 155XL for sale for $1100 locally, and maybe a Garmin 155 for sale for $700 on eBay. Along with these I'd need a $475 ARINC-429 adapter from Dynon.
I was thinking of getting one of these and get non-precision GPS approaches for $1200-$1500. Along with the ILS my plane will be IFR legal.
Is this crazy? I could go into it eyes wide open and understand the risk that nav updates might dry up just like the Apollo units. Then spring for a newer Garmin (GPS 175/ GTN650) when they come down in price.
Old 07-27-2020, 04:20 PM
RV6_flyer's Avatar
Do not throw good money after bad. You are already IFR by having the VOR and ILS equipment with your current GPS.
Most of the older IFR GPS units require a CDI and an ACU to be IFR legal in addition to having the database for the approach being flown.
The question to ask about the 155XL is will the spare parts run out before the database is no longer published?
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 07-27-2020, 07:55 PM
Ah good points. It does seem nutty to replace my current GPS with an even older GPS. So the TSO would only cover certain CDIs or annunciators and the Skyview couldn't do that?
Old 07-27-2020, 08:24 PM
Strictly speaking, the TSO covers everything - antenna, indicators, panel placement, etc. But the FARs don’t say ‘TSO’, they say ‘approved’. And while so far, the faa has not approved a main gps box unless it is TSO’d, they seem content to let EAB aircraft use indicators, etc., that satisfactorily perform the same function as the TSO’d units. So short answer, yes, the Skyview CDI/HSI can be used. It can also replace annunciators if it can replicate the approved ones. Many builders have mounted antennas not in compliance with the TSO’d installation instructions (which personally I think is a bad idea) but so far the FAA has been silent. BTW, unless the rules have changed, you can continue to use your existing gps even with an expired database for enroute only. You’re supposed to check that you have the needed waypoints, and that none have moved.
Old 07-28-2020, 06:55 AM
DennisRhodes DennisRhodes is offline
Get the iFly for your android or apple phone and try that .30 days free. With an "IFR" update you will get all the RNAV and waypoints there to fly that approach ofcourse with an "observer" see how that works and maybe an Ipad would cover that need. All the plates and overlays as well as target altitudes are there on the screen. But a bit small on the "phone" display
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 08-01-2020, 12:21 AM
I already have ForeFlight. I am looking for a cheap, FAA approved way to fly IFR approaches. I don’t think iFly would help me - I want to be able to legally file and execute a IFR flight plan that includes a GPS approach. (Although I would have no problem doing this in an emergency.) I think iFly is only for situational awareness.
