Old 08-06-2016, 08:04 PM
Reboot Reboot is offline
Default Fuel tank leak
I noticed that my fuel tank was leaking earlier this week. So being a new RV owner and very little experiance with sheet metal work, I did the obvious and removed the tank to see if I could find the leak.
I found the leak however it is beyond my ability to fix it. I do not have the tools required nor the experiance to fix it properly. The back lower seal has a couple leaks and I suspect it will need a few rivets replaced.
So I would appreciate some advice on locating someone to help fix the tank. Does anyone know a shop or mechanic that I could reach out to?
Mike
Mike Reece
RV-6A Purchased Flying
RV-3A Purchased Flying
Old 08-06-2016, 08:09 PM
twcroy twcroy is offline
I had a slow leak in the left tank about three years ago. My A&P fixed it during the annual. Not sure if that helps. Keep in mind A&Ps know certified airplanes and not always our more delicate and ingenious RVs. So you'd want to find someone who is patient, meticulous, and careful. Hope this helps some.
Old 08-06-2016, 08:10 PM
There should be a bunch of RV people around where you live. If the tank is already off, that is half the battle!
Good luck and have fun with your new plane.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 08-06-2016, 11:17 PM
Mark C. Mark C. is offline
Mike, I did hear back from Steve at DKB. He will contact you next week regarding tank and other concerns.. Mark C.
Old 08-07-2016, 07:53 AM
chazking's Avatar
chazking chazking is offline
Default Saint Aviation
Call Jesse Saint (VAF advertiser in FL).
He has a 6A & knows the plane well.
Ch?z King
Old 08-07-2016, 08:44 AM
Thank you for all the suggestions...
Mike
Mike Reece
Old 08-07-2016, 10:37 AM
olyolson's Avatar
olyolson olyolson is offline
Heard good things about this company:
http://www.weepnomorellc.com/services.html
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
