Gary, if you followed the gross weight recommendation from Van's, what would your useful load be?
Mine is 570 lbs at the 1600 lb limit.
How many of those pounds can you put in the baggage compartment before you hit Van's AFT CG limit? Hard to believe that it is more than 40 pounds.
