Old 03-21-2021, 08:01 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
If you're looking at putting this in a -10, it will weigh at least 100 pounds more than a 540 with cooling system and gearbox.
Reliable gearboxes with provisions for hydraulic C/S props are expensive (much more than the crate engine itself).
If you're not an engineer or gearhead, I wouldn't recommend you start down this path.
Most folks now are using LS3 or LS7 derivatives.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 445.9 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 03-30-2021, 10:18 AM
TonyWilliams TonyWilliams is offline
Where can we read about these folks?
