I need to add a cable strain relief back onto a discrete wire based data cable after the original heat shrink tubing has been cut off. Does anyone have a favorite way of doing this for a D-Sub shell based cable?
The pins are not removable (solder cup style) so removing all connections and putting a new heat shrink on and soldering back up is work which I'd like to avoid.
I've been looking at a product called Sugru that looks interesting. It's kind of expensive but the idea is right.
Is there anything else that anybody uses?
Scott
Scott
