search for Delrin Rod at Aircraft Spruce.Source where to purchase?
You should be able to look at the plans to figure that out. On the RV-9 the correct diameter is 7/8". It might be different on the RV-8. The plans should have a full size drawing of the aileron attachments to extrapolate the necessary diameter to get you down to where the stops are on the brackets.Diameter?
Believe it or not, the aviation dept at Lowes has this part - cut to size and with a center hole that fits perfectly for the bolt.
It's in the hardware dept in the section where they have the drawers of specialty bolts, etc.
Dan
Ditto here.
350 hours, always hangar'd. When they wear out, I will spend another $3 and replace them. Acutally, I bought extra when I got these.
Hi Bruce-On the RV-9 the correct diameter is 7/8".
...a 4 pack of 3/4" dia. wheels ... The wheels have roller bearing & threaded axles...
I was in Mike Bullock's build log (see Van's builder web site list) looking for something else, and ran across his aileron stop page. He used 3/4" nylon. I have no idea how it's held up.
