  #11
Old 05-19-2021, 11:10 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
[quote=SkyDreams09;1526751]You are correct, even a small 30-50lb increase changes it for me. Especially with the 4-gallon unusable fuel./QUOTE]
RV-12 fuel tank is usable to last drop. You might be referring to 4 gallons minimum for takeoff...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 670
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 05-19-2021, 11:15 AM
rvbuilder2002's Avatar
one of my big questions is what will be the resale value of 1320# gross weight aircraft when 2000# plus LSA are available? Is there still a market? It has to have an impact.
Just to clarify, the RV-12 doesn't have 4 gallons of unusable fuel.
I have personally landed with 2.5 gallons remaining. The tank can actual be run nearly dry in flight if a situation occurred that someone accidently ended up using all of the required 30 minute VFR reserve.
The 4 gallon minimum is a limitation on taking off.
It is also recommended that no long term extended steep climb be executed with less than 4 gallons on board.
Shallower cruise climb pitch angles and any other coordinated maneuvers that would be used in normal flight modes are not an issue.
Scott McDaniels
Hubbard, Oregon
Old 05-19-2021, 12:08 PM
SkyDreams09 SkyDreams09 is offline
Wouldn't the concern for a go-around be equivalent to a take-off? Where I trained for the RV-12 puts a hard-line on leaving 4 gallons plus in the tank to avoid that exact scenario.
Old 05-19-2021, 12:22 PM
Leave it to the government and the FAA to botch something good. They could seriously screw up a wet dream.
Originally Posted by BobbyLucas View Post
You may want to read this recent article: "Spring 2021 Update on FAAís Proposed New Regulation for Light-Sport Aircraft & Light Personal Aircraft"
https://bydanjohnson.com/spring-2021...onal-aircraft/
LSA may not change as much as we hoped.
Old 05-19-2021, 12:31 PM
There is a header chamber (for lack of better description... it acts in the same way a header tank does) in the tank at the fuel pick-up that captures enough fuel at the location of the fuel pick-up to allow an unrestricted climb for a few minutes at a low fuel level. Easily enough to execute a go around and climb back to pattern altitude.
Scott McDaniels
Hubbard, Oregon
Old 05-19-2021, 09:01 PM
RFSchaller RFSchaller is offline
Walt,
If you get a new AW certificate you will also get new OLís which may be much more restrictive than hat you have now. For example, my 12 was licensed in March 2012 and my OLís permit IFR in IMC if equipped. My understanding is that guys getting ELSA AWs now do not have the option for IFR in IMC.
Rich
Old 05-19-2021, 09:48 PM
seagull seagull is offline
[quote=RFSchaller;1526935]If you get a new AW certificate you will also get new OLís which may be much more restrictive than hat you have now. For example, my 12 was licensed in March 2012 and my OLís permit IFR in IMC if equipped. My understanding is that guys getting ELSA AWs now do not have the option for IFR in IMC./QUOTE]
I speak from personal experience.
I did an "N" number change on my -12, It started 10/20 but because of COVID the gears moved slowly. It finally got moving 2/21 and is was issued FEB/2021.
In reference to what you speak this is directly from my Special Airworthiness Certificate;
19. Instrument flight operations are authorized if the instruments specified in ß 91.205(d) are installed, operational, compliant with the performance
requirements of, and maintained per the applicable regulations. All maintenance or inspection of this equipment must be recorded in the aircraft
maintenance records and include the following items: date, work performed, and name and certificate number of person returning aircraft to service.
(49)
There is nothing different in this AW certificate that wasn't in the original AW that was issued in 2015.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 05-19-2021, 10:44 PM
[quote=NinerBikes;1526961]
Originally Posted by seagull View Post
He mentions 2012... something might have changed in 2013.
Read Rich's post closer, he talks about "My understanding is that guys getting ELSA AWs now do not have the option for IFR in IMC."
I directly addressed that issue.
My date is 2021, as current as you can get, and I am still allowed to fly in IMC "if equipped".
-- Walt --
Old 05-20-2021, 10:06 AM
Amadeus Amadeus is offline
[quote=seagull;1526963]
Pilot decision making is crucial whether flying an LSA, Cessna 150, Diamond DA40, F-22 Raptor, day, night, VMC, IMC, alone or with a passenger. I would NOT take an RV-12iS into IMC weather but it would be nice to get a clearance for passing through some wispy clouds en route without deviation or to even get through a low non-convective cloud layer to VFR on top. Can we, as pilots, not be trusted to make decisions at this level?
Eliminated Cubcrafters and Kitfox kits and narrowed decision to Zenith 750 Cruzer or RV-12iS.
Are there others I should consider?
Old 05-20-2021, 11:29 AM
rcarsey's Avatar
rcarsey rcarsey is offline
Well, I just got my E-LSA AW just a few months ago. It contained the standard language that the plane can be operated Night VFR or IFR as long as it has met the equipment requirements in Part 91.205(c) and (d), respectively.
Before flying in IMC, I would remove the placard on the panel that says "flight into IMC prohibited" on the instrument panel, and update the POH.
If you're in an S-LSA aircraft, you can't make those changes.
Flying in IMC without also equipping with pitot heat, alternate static, and two separate attitude gyros/sensors is probably not smart though. If you're talking about a whispy or single, well-defined cloud.. then... ?
Rob Carsey, North Brunswick NJ
RV-12iS (N713) / Completed 12/2020
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
