  #11
Old 03-14-2021, 04:58 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
It took two guys a total of eight hours to remove engine mount. As stated above, Van’s won’t receive mounts from their supplier until May 3.
I have located a welding shop that specializes in TIG. We will make a jig to hold 189mm vertical spacing between mounting pads per Rotax Engine Installation Manual. Crack will be chamfered with a carbide burr for good weld penetration. Tubing will be preheated to around 800F, TIG welded, and cooled slowly. A Chromoly 4130 split over-sleave will be welded in place to complete the repair. Lucky thing (if you want to call it that) the crack is in the straight upper tube and not the curved lower tube. I will find somebody locally to strip and powder-coat.
Brilliant white color is good for showing cracks, as I’m finding out first hand…
Click image for larger version
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 670
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 03-14-2021, 05:22 PM
seagull seagull is offline
Jim, can you share some pics of the crack close up and distant showing the relationship to the overall mount.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 03-14-2021, 06:46 PM
NinerBikes NinerBikes is offline
Will you be putting in all new rubber bushings while you're in there, to remove any sag?
Donated
2012 RV-12, #120212 N72DJ KWHP based.
"Time to Spare, go by Air."
Old 03-14-2021, 06:49 PM
Piper J3's Avatar
Now that the mount is no longer bolted to the engine the crack has closed up and vertical spacing between mounting pads is less than 189mm. When we jig the mount for 189MM vertical spacing between mounting pads the crack will separate just like when it was bolted to the engine. So, when welded, the mounting pads will line up with the engine bolt holes.
Name:	Screen Shot 2021-03-09 at 3.53.12 AM.png
ID:	9317  Click image for larger version
ID:	9318  Click image for larger version
Old 03-14-2021, 08:21 PM
Is this the correct location?
-- Walt --
Old 03-14-2021, 09:47 PM
jrock836's Avatar
jrock836 jrock836 is offline
Man, that looks to be completely broken.. Is there still part of the tube on the other side not broken, or is it a clean break? I only have 189 on the Hobbs meter and don’t see any breaks in mine yet, but you definitely made me decide to pull the cowling and check last night. Thanks for the info.. I see another SB coming out soon... Wonder how much a new and improved engine mount is going to cost? $$$$...
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
LSRI-A for N49DD / EAA / AOPA
Pvt Pilot since '79! / USNR - MA2
Retired LEO / PADI MSDT / SDI OW Instructor
Scuba Equipment Tech (PT Retirement Job)
“If you can walk away from a landing, it’s a good landing. If you can use the aircraft the next day, it’s an outstanding landing.” – Chuck Yeager
DONATED
Old 03-15-2021, 03:18 AM
Piper J3's Avatar
Yes. Lower left (pilot side) engine mounting bolt.
Old 03-15-2021, 07:22 PM
Crafting N112DR's Avatar
Crafting N112DR Crafting N112DR is offline
Default It smells really bad!
Oh No!!, I smell another SB in the Wind and it smells really bad.
___________
David Rohrlick
PPSEL, A&P
N112DR (RV-12iS)
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
https://youtube.com/c/CraftingN112DR
VAF donation made for 2021
Old 03-15-2021, 07:26 PM
Piper J3's Avatar
Yes, new rubber bushings and all new High Performance Silicone Heater Hoses.
Old 03-15-2021, 08:57 PM
RFSchaller RFSchaller is offline
Bite your tongue, David!��
