Old 06-04-2021, 09:27 PM
Texas Barnstorming Museum Texas Barnstorming Museum is offline
Default 5 year hose replacement questions
Our RV-12 has 1.5 hours on it since being built and certified in 2015. We are giving the airplane away in a raffle, so I want it 100%. I don’t want the winner to be faced with a bunch of items that haven’t been done.
We are doing the annual condition inspection now, and once complete will fly off the remaining time requirements. As y’all know, the rubber items are life limited. Are “kits” available that have all the necessary parts all together? In looking at the California Power Systems catalog, it looks like I have to order the hoses all individually, and it seems like since this is such a prolific design, there would be companies that offer compliance kits that include everything instead of the individual approach. CPS is the only shopping I have done. In reading the forums, I see lots just make their own hoses for the fuel, oil and coolant, but I’d rather go with a factory made parts, if for nothing else than liability. Where else should I look? I appreciate any advice.
Jim
Old 06-04-2021, 11:00 PM
jrock836's Avatar
jrock836 jrock836 is offline
Highly recommend Tom @ Flightlines for any fuel or oil lines that you might need. If you’re not sure about what you need, he is very good at looking at photos and figuring it out for you. Very good quality lines.
https://www.tsflightlines.com/
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
LSRI-A for N49DD / EAA / AOPA
Pvt Pilot since '79! / USNR - MA2
Retired LEO / PADI MSDT / SDI OW Instructor
Scuba Equipment Tech (PT Retirement Job)
“If you can walk away from a landing, it’s a good landing. If you can use the aircraft the next day, it’s an outstanding landing.” – Chuck Yeager
DONATED
Old 06-05-2021, 12:12 AM
BobTurner BobTurner is online now
Tom posts here as ‘TS Flightlines’. He can get you Teflon hoses with no 5 year limit.
Old 06-05-2021, 06:24 AM
Thanks, reached out to him this morning.
Old 06-05-2021, 06:47 AM
cactusman's Avatar
cactusman cactusman is offline
Jim
2015 the fuel lines should be teflon already. Oil lines have a 10 year life. So then you get into coolant hoses, fuel pump drain hoses, etc. Might want to look at the ELT battery expirations as well.
I would look more into all the major S/B's. Nose gear, engine mount, stab reinforcements, etc. Carb floats too.
John
RV12 Built and Flying
RV10 Started
Old 06-05-2021, 07:20 AM
Default Wow, thanks for the responses.
Thank you for your responses. Excellent.
For the fuel lines, is there an easy way to tell if they are Teflon? All the hoses are fire sleeved.
We are looking at the other service bulletins and trying to comply with those as well, although the nose gear fork and strut are back ordered at Vans with an expected ship date in 6 months. Our plan is to comply with all that we can prior to giving away the plane, then if any others remain us complied with, the Vans parts will be shipped to the new owner.
We are ordering new sockets, diaphragms and fuel pump, which are in stock.
Old 06-05-2021, 07:43 AM
Aircraft Specialty Aircraft Specialty is offline
Good morning. Tom and I published a quick reference guide for the RV-12 due to the multiple variations of hoses that were installed on the aircraft through the years.
http://aircraftspecialty.com/PDF%20D...se%20Guide.pdf
Hopefully this helps a bit. Please feel free to reach out to us anytime to discuss.
Steve
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
