Old 09-20-2006, 07:19 PM
cnpeters cnpeters is offline
Default Ooops! Extra dimple hole in HS skin.
I have heard of builders doing this, and seek repair advice. The original extra dimple was flattened with the squeezer and flat sets, then after the pic was taken I deburred the extra hole (after dimpling the proper one) with a jeweler's round file. The plan is to go ahead and rivet as usual, then fill the adjacent hole with some epoxy and sand smooth. Sound good? Other tips?
Carl Peters
St. Louis, MO
RV-9A finishing kit
http://www.mykitlog.com/cnpeters
Old 09-20-2006, 09:16 PM
gbrasch gbrasch is offline
Guest
Default Extra Hole
Welcome to the club of those of us that have! Keep on building!
Old 09-20-2006, 09:43 PM
svanarts svanarts is offline
How would an "oops" rivet fit in there? If you drilled that hole out to #30 would most of the extra hole be gone? If so that may be an option for you.
Scott VanArtsdalen
www.airprayer.net
Old 09-20-2006, 11:03 PM
dr cooper dr cooper is offline
Default Oops!
I did the same. Was mortified! Vans said, "Don't worry, just put the rivet in." Once it is painted, chances are, you'll never see it. I haven't painted yet, and I'd be hard pressed to find that oops.
I don't think an oops rivet would be of any benefit, because it has the -3 head.
Cliff
RV9A fuse
Chase, BC
Canada
Old 09-21-2006, 08:34 AM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default Count me in
I've got one also, learning how to PROPERLY use a pneumatic squeezer. Called Van's, solution was to rivet and keep on building.
No sweat.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 09-21-2006, 08:41 AM
admin admin is offline
Administrator
Welcome to the club. My 'oops extra dimple hole' was on the VS....not even sure I remember which side now. Can't see it under the paint.
I read somewhere each airplane needs a small imperfection so that the evil spirits will have a place to exit. Something like that.
b,
d
Doug Reeves
Editor: www.VansAirForce.net
Owner: Delta Romeo, LLC.
Old 09-21-2006, 06:48 PM
cytoxin's Avatar
cytoxin cytoxin is offline
Default have an extra one
just like it for the left side. i should have used it.
William Weesner/ still kicking.
Old 09-22-2006, 05:32 PM
TSwezey TSwezey is offline
It looks like you have a crack in there. If that is the case I would drill out the crack with a 40 bit. I would then use the original hole and put the rivet called out in the instructions in the hole. I would then add a rivet on either side to help relieve any stress that might be applied to the area. If you drill to a 30 now you will not completely get the crack or the other hole. If there is no crack, I would do what you stated and just add a rivet on either side for safety sake. Now if it were in the middle of the HS, I would have and did exactly what you stated.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
